35×11.5r20
Jcndsu
Does anyone know if a 35×11.5r20 will fit with just a 2" level? The rims would be 20x9 with a +10mm offset. The tires I have in mind are nitto ridge grappler.
Thanks
They should clear. I’m running 295/70r18s (34.5x11.50) on stock wheels and have room to spare on a 2” level. Might be close but should clear
@Tjhook Are you running that size on stock suspension? or the 2in lift? I want to run this combo on 4x4 Off road with air suspension.
I am looking to do the same setup. I thought I would need to get new wheels, but your rig looks great with the stock wheels. No spacers?
Thanks
I’m running 35x11.50r20 on a 9” +20 offsett. I have the Readylift but did not use the preload spacer, so the front is basically 2” lift over stock. I also have the off road group which adds another inch (3” total). Tires fit pretty well but I do get a little rub in full lock. Nothing that I need to trim but you may have a slight rub
I have a 2wd bighorn if I get the Mopar 2 inch lift I should be able to fit 35's?
I just put on the Mopar 2”. Running 305/55/20 and 20x10 -19 offset. I’m having some rubbing at flex. Looking at getting an additional 1/2 to 1” Lift on the front. Hoping that fixes it
You got a 2wd or a 4wd?
I have 35x11.5 ridge grapplers on Laramie 20 stocks with a 2.5” suspension maxx leveling kit. Only rubs at full lock, not enough to bother me. Truck is 4x4 non off road group
Does anyone know how much of a height difference there is from a stock 2wd and a stock 4wd with no extra packages is?
