Adjusting PSI Value on 25’ Rebel
Johnsamir
Hi, not really sure if there is a straight answer to this or not. I got a set of 35x12.5x18 installed on my 25 Rebel, tire sensor is on because stock tires need to be at 55 PSI where as my Baja Boss’s need to be at 50. I know AlfaOBD is what people used in the past and that’s not an option right now, but I didn’t know if a dealer could do this or not? Is there a different solution, I know AlfaOBD was for way more than just adjusting the value for tires, I don’t need anything too involved. That light on the dash is just so annoying to look at.
Thanks everyone!
You can, but i haven't bothered. When the light goes out it just means I have to let out the winter air. It's a nice reminder
Dealer is going to charge you more than AlfaOBD, a security bypass, and an OBDII module will cost you. They most likely won't even do it for you. AlfaOBD is also useful for changing tire size so your speedometer and shifting is correct.
Alfa does not work on 2025's yet
I'm running the Baja Boss AT and ended up just bumping them to 55 to deal with the TPMS light. Annoyed the crap out of me.
