2025 Bighorn 1500 Cigar Plug
Shutterbug57
The cigar plug on top of the dash is always on. Is there any way to change a setting to have this plug go on or off with the engine bring on or off? This is the perfect place to plug in a dash cam, but have to plug it in and out all the time gets old.
You can on the 2019 to 2024 by moving the fuse. I'm not sure on the 2025 though. Use search to find the info on the older ones and see if it will work on yours.
Thanks for the input. I found the posts and fuse box under the steering wheel.
