What size tires can I run on my Eibach stage 2R kit?
BDizzle0709
I am installing this Eibach Stage 2R kit and these RC UCAs. I am keeping the stock 22” rims.
My question is what is the largest tires I can run on the stock rims?
I have been thinking about 285/55/22s
I have 33x12.50R22 on stock rims.
My guy said 35/12.5 would rub bc of the offset of the stock rims. Is 285/55/22 equivalent to 35/11.5?
295/55R22 should be fine. 285/55 you can run stock with help of a heat gun on front wheel wells.
True. You didnt mention stock. You usually need +1 or -12 offset. If you are going to air down you need the -12.
