Nastynate21
- Feb 27, 2025
think i made a mistake when swapping my transmission pani got the tranmission up to temp and ran it through the gears but then i shut it off and filled it until a stream.
I did it twice the first time there was no oil that came out so i put about another quart into it. It took about 7 quarts in the ppe pan.
I don’t have access to a lift anymore to work on the truck should i just run it up to temp in the drive and pull the fill plug and see if it is a stream on the ground? My truck in the drive way measured to be pretty level. I’ve been driving it and it heats up to 195 when warm, which i think should be high considering the pan is deeper but it is within range
