Tilt Mirror Memory Issue
captainsky
I have tilt mirrors turned on and after a couple tilts the mirror never goes back to the same spot...it tilts slightly up after every time it goes back to normal position. Every couple days or so I need to re-position my mirrors so that they are in the correct spot.
Has anyone else encountered this on the 2025s?
lol i deal with this last 10000 miles put them where you want them hit s on the door they work a little longer
I reset the memory every time and when I hit the 1 to go back it doesn't work. That works for you?
On touch screen make sure its in 1 or 2 on comfort setting not off just set mirrors and hit s.There are so many setting you could spend hours setting everything to your profile.Sometimes it docent always go to your profile. After i start it i always hit my profile manually.
