Front Sway bar links
TheMushyButt
What does everyone suggest for front sway bar links?
I’m replacing my front struts this weekend. Figured I’d upgrade the end links also.
The front end seems to dip and sway more than it used to.
Seems to me the consensus is that the OEM ones are trash. My drivers side is shot after 23k miles…
Some have used the suspension max ones with success. I have a set but haven’t put them on yet.
I HAVE SUSPENSION MAXX AND THEY ARE GREAT I SEE U HAVE A 2" MOTOFAB LEVEL KIT. YOU WILL NEED TO GET THE CORRECT LINKS FROM SUSPENSIONMAXX TO ACCOMIDATE FOR THAT FRONT LIFT. WOULDNT HURT WHILE UNDER THE TRUCK TO CHANGE OUT THE SWAY BAR BUSHINGS ALSO
Not a consensus at all, after the initial run of 5th gens(loose link nuts), they have been ok. The bushings have a higher failure rate in my experience.
🤷‍♂️ glad your experience is different. Theres just a glut of threads about them failing..both the older version and newer…where owners are chasing a clunk and it leads them to the sway bar ends. Im also aware the forum doesn’t necessarily represent the totality of ram owners, more just a small sampling that typically find a forum when they have a problem.
I wish they were better because i dont personally want to mess with the suspensionmaxx ones. Call it ignorance but they just look complicated and fragile to me..despite understanding they are not. I still may end up replacing my blown one with an oem replacement. For now i just live with the infamous clunk.
