1500 HO axle feedback
Weisp
I`ve seen some vids on some 2025`s showing some underbody imperfections. For example oil leaks coming from the drain plug of the trans. Axle contact/wear.
As for the leak, i am all fine. The axle however shows same symptoms both sides. Aluminum wear (light). Any feedback from you guys?
That's from doing full steering lock turns. Those are normal, and the control arms are designed for that.
Normal bump stop for steering.
That's what I was thinking before I saw your response.
Welcome glad you are here! Good luck with it
Any pictures of actual truck. I like looking at them 🤪
