Halo LED and Automatic High Beams
meloftis
Afternoon All, I just purchased a 2024 RAM 2500 and love it. So far, what I've seen with it is the halo LED (the LED that goes around the perimeter of the light) doesn't light up. When I first crank the truck up, it will come one for about a second, then turn off. The LED on the passenger side is working fine. I checked the fuses but I don't know what else to check to see about getting this fixed.
Secondly, the automatic high beams doesn't seem to work. I have it enabled in the Uconnect settings, but no matter if I have the switch is bright or not, the headlights will not automatically go high beam to low beam. For this, I've tried resetting the Uconnect back to factory settings, but yielded no results.
You might have better luck in the Homepage - HD Rams forum. This is the 5th Gen 1500 Rams site.
But it is possible bad board in the light. Might need replaced.
