Amp research steps for 25 Ram 1500 quad cab
Trigrhappy
Yo, anyone install these amp research steps for a 25 ram 1500? If you have I’m on this step in the pictures. Can someone tell me what the blue wire goes to and the white wire goes to. Have to put a post-taps on this plug. Just confusing because there is no tan wire where this picture says it should be.
Did it get it figured out? I'm debating on getting these or other power running boards. wonder if they meant the brownish wire there in your pic?
Yes, fully operational and works as it should, very easy to install. There instructions had a tan and blue/white, my truck has the blue/white and white. Just the white replaces the tan in my case. Hopes this helps and amp was very responsive. Hit me up with any concerns
Won’t let me post a video only pictures
Ah ok looks clean. I like how it doesn't show much when its up but there when you open it up. Did up add any all weather mats yet? I just got mine a week ago and looking to add these few things.
I followed your advice, but this didn't work for me. Still stuck using the app to control them.
Awesome! You saved me. I couldn't figure it out. Thanks for the update! 👍
We're you able to drill through the pinch weld? I've had difficulty getting through. I am using a Milwaukee hard metal bit.
Did this and the steps work but stop working after a few minutes
