Bilstein 5100
Ok. Newbie here with suspension parts. I've got a 21 Ram 1500 (Limited) with the air suspension. I'm not having any issues but I've always been a big fan of Bilstein struts. I'm not looking to gain or lower height, just want the most comfortable ride and Bilsteins have been the ticket with my trucks in the past. Summit says these struts work with the Ram 1500 but Bilstein's site says not to use it with the Air suspension. Just wanted to check here to see if anyone has run the B8 5100 with the air suspension and if so, can you provide feedback.
Did you look under your truck ? Did you see anything that looked like a standard strut with a spring around it ?
No. I saw a standard strut in the rear with the air compression where the spring would go. In the front, I saw a standard strut with air compression around the strut where a normal spring would go
I installed the rear 5100s on my limited w/ air suspension, they fit just fine and ride great. No issues and had them on nearly a year.
