Push start won’t work
mikeyb9370
2020 power wagon push start won’t work battery is good key fob is ok was told maybe the RFHM HUB MODULE where can I buy one at and is it easy to replace I’m looking around says underneath back seat any body have any luck installing a new one
You will need the dealer to program it to your truck. It's a security module. It's behind the back seat. You can try to start the vehicle by pushing the start button with the bottom end of the key fob. Do you have a rear window leak?
I don’t have a leak I tried pushing the start button with key fob it starts sometimes and sometimes it doesn’t this time it’s been a week lol everything works but just won’t start
just had my push button not work as well. would click and nothing happened....ended up being the starter. Changed it out and works great again.
This happened on my 2023 ram about 2 months ago, ended up being the push button itself that was broken. Covered under warranty but I believe a cheap part to buy.
Had your starter ever sounded bad before?? Mine sounded fine but now I have nothing
Nope, just out of the blue....click...and nothing..i initially thought my battery was dead so I used a jump starter ...apparently it was just enough jolt to start it up....the next time it happened it just didn't do anything. Found a YouTube of Truck Central..the guy has a 2019 Ram limited with 200k+ miles and one of his videos described the exact same thing.
