What is selecspeed?No one?
I have hill decent control, which are are supposed to be able to adjust the speed on. I've used it a couple times, but could never figure out how to adjust the speed. It was set at 1.5mph and wouldn't change. Owners manual says to use the cruise control buttons to change it but they did t do anythingFrom the original press release:
Selec-Speed Control
Selec-Speed Control is standard with the eight-speed automatic transmission and manages vehicle speed in "4LO" while traversing off-road terrain without requiring throttle or brake input, allowing the driver to focus on steering. Selec-Speed Control is activated using a button on the dashboard and can be adjusted from 0.6-5 mph simply by using the Auto Stick shift control or paddle shifters mounted behind the steering wheel.
