35/12.50/20 what’s the best PSI?
Mopar_23
I mounted 35/12.50/20 on my 2019 ram 1500 2wd with a 2.5 leveling kit. What’s the proper psi for those tires? I don’t haul anything , it’s my daily driver. The tires are Haida RT. Load E/10ply
Nobody can give you an accurate answer. You will have to find out what works best for your set up. As mentioned in previous post, do a chalk test
tire pressure depends on the load rating. here use this to figure it out.
I played around with that just to see what it showed for my current 35" tires, and it was about 10lbs higher from where I actually run them.
The tire shop aired them up to 40psi. That chart saying to air them at 40psi. Hmmm
stock oem rebel recommended tire pressure is 55 in the front and 45 in the back so I use that but if I were to get bigger tires id definitely use this calculator. its legit! of course its only a recommendation, inflate them to whatever suits you best!
I've been doing this 55/45psi with good result, but I tow a car trailer and camper.
