Swapping Wheels and Tires on 2025 Warlock
rb13
I've been searching the forum, but haven't seen anything about anyone swapping wheels and tires on a 2025 Warlock. I like the Duratracs, but I've had Toyo AT3s with Method wheels on all my past trucks. Anyone know if it's possible to install 18" Method wheels with 35" (actually 34.5") Toyos?
And if anyone has swapped out their wheels or tires, I'd love to see some pics.
Many aftermarket 18-inch wheels don't fit these trucks, as they don't clear the brake calipers. OEM 18s work, but be careful when going aftermarket.
It’s 2022 1500 backcountry, it comes with 1 inch factory lift . I installed a 2 inch leveling kit in the front . The wheels are 35”x 12” .
I was hoping to go with 17”, but had noticed that there isn’t much clearance with the calipers and OEM wheels. Thanks for the heads up.
Looks pretty sharp! Any issues with rubbing?
Did you swap the 2” leveling kit with the 1” lift or add to it? I’ll be honest, I’m not familiar with lifts vs leveling and how they work.
No rubbing at all . I disassembled the front suspension and added the leveling kit on top of it. It kind of looks like a hockey puck with holes. Just like the backcountry edition , the warlock comes already 1 inch higher than the bighorn and laramie . Due to the off-road package. Which already gives you more clearance. The rim offset it’s what you have to be specific with . I’m actually selling my current truck and I will be installing the same rim and tires on my new 2025 Laramie , without air suspension. I’ll take some pictures of the process and keep you posted.
That’s really helpful. I was thinking about going the opposite way and removing the 1” lift from the back, hoping that would level things.
What’s the offset on your wheels?
What’s the offset on ?
