2023 Ram 1500 Limited - Trailer Surround Camera System 360 Installation - Working Solution
ndsvend01
In the process of adding the trailer surround camera system.
Took a bit of research to understand the different cameras and so on so this is my journey, maybe it will help somebody in the future.
I did not have a 12 pin connector on my bumper before starting.
I only had the 4/7 pin connectors on the bumper.
Parts list:
68527709AC - Trailer 360 Camera System
68522624AA - 7/12 pin connector that goes on the bumper
68525632AA - 12 pin harness (part of 5th wheel prep)
68509331AB - Trailer camera gateway module that goes behind the dash
Worked with the dealership to figure out some of this but they also referrenced the forum.
They enabled sales codes AHT and AHX which is what is associated with my truck instead of XN1 and this now shows the "Trailer" option under "Camera".
Before turning on the sales code the Trailer section was not there.
Under AUX there was AUX1 and AUX2 before turning on the sales codes. Now there is only AUX2 available.
I looked behind the dash for the wiring where the trailer camera gateway is going to be installed and the plugs were there and easily accessible and covered with tape.
Pending arrival of the gatway to install.
Underneath the truck I had to look around and see if there were any extra wires or harnesses.
Found a 12 pin connector that resembles the type of connection needed for the cameras. It was on the driver side above the exhaust.
It has a protective cap on it.
In theory, I should be able to take the harness purchased above and plug this in and the camera system should work.
Will update next week.
After a **** ton of hours trying to figure this out and researching/tranlsating this stuff........
I have got it to work.
Just need to install on the trailer.
Posting the solution so if anyone needs the pin outs they can duplicate it.
You will need to buy 2 of part #68525632AA and splice them togethere because you need two female ends to connect the bumper connection and the chassis harness connection.
Below is the pinout I used.
This is what the crossover cable look like. This is how it looked for testing. Need to clean it up and finalize the connections.
It is def not plug and play.
I had to figure out which wires need to go where since the pinouts are different on the trailer and truck from what I was expecting.
This was initially the output I was receiving but just needed to figure out the video portion for the crossover cable (pins 7, 11, 12 on the trailer side).
The power, ground, and BUS connections I guessed on with trial and error.
This is the output after making sure that all the connections were done using the pinout above.
Cameras are laying on the ground inside the box.
XY501A is the connector that is underneath the truck with the blank cap on it.
I got my truck on 2022 and it came with that box containing the 360 trailer camera kit, I’m thinking about installing it in my Rv, I see that you have a lot going on makes me wonder if I have to do all that as well I believe the connection you didn’t have on bottom of the bumper I do have it just to make sure can you send a pic of how everything looks hooked up on the truck ? I will upload picks about my set up as well I’m thinking the only thing I might need is the gateway module, do you know if they install those from factory or do I have to get one for sure
Try plugging in the camera system.
If you get a blue screen then that means no gateway I think.
If you see aux 1 and aux 2 that means you don’t have the sales code enabled for the trailer camera system.
The hardest part for me was that I had no 12 pin connector on the bumper so trying to figure that out was painful.
In the process of installing the camera system on the trailer. I will get post installation pics up once done.IMG_1906.jpeg
Done with the mocking up.
Need some grommets for the roof and then cleaning up the wiring.
Front camera won’t go up until I find a solution for the rounded roof but 3 cameras will def help out in the interim.IMG_1921.jpegIMG_1920.jpegIMG_1919.jpegIMG_1914.jpegIMG_1917.jpegIMG_1911.jpegIMG_1908.jpegIMG_1910.jpegIMG_1912.jpeg
Plugged everything into to truck and they showed on the screen I guess I do have a gateway lucky me, all I need now is install on my Rv
Nice!!! Lucky
What si the quality in the trailer surround?
Mine is a bit fuzzy but I think it’s related to the splicing I had to do.
There is shielding and twists in the pairs of wire.
What type of truck do you have? 1500?
Can you take a pic and send part number of the wire harness between the connector underneath the truck and to the bumper underneath.
How is that setup on yours.
Quality is good as good as the 360 on the actual truck, just looks weird on that picture
Yes I have a 2022 1500 Ecodiesel Limited
Yea I’ll take a pic and upload it I’ll see if I can get the part number
I’m not exactly sure which is the part you’re looking for hopefully that helps if you want more pics let me know
Thanks
If you could get the part number for the cable that sits above. The 12 pin please.
That would be very helpful so I can purchase that and avoid the splicing I did.
Not sure if it would work but might
Every time I went to dealership they would not find anything and most info I found was for 2500/3500s
Guys way to dig this out! I have everything ready to go but I seem to be missing the two connectors for the gateway module which is shocking to me. I ordered my 2023 15
00 with trailer cam wiring so I have the connector and harness to the uconnect from the bumper. I have looked high and low under the dash and see no taped up connectors for the camera gateway, any ideas? Did they really build with different harnesses? Or were these connectors only installed on 2500/3500 trucks? Thx for any help. One more detail, because I purchased the trailer camera install wiring - I tried just hooking up the 360 camera kit and it did show on my unconnect, but it was only via Aux1 and all the views were slammed on the left half of the display without the surround menuing on the uconnect. But I could see all the cameras. Is this just a matter of enabling the sales codes to get the correct display options? I have attached pictures of what I get when the camera system is connected. I can see them all through Aux1. However the views on the right dont selsct and defaults to rear view. This almost leads me to think I just need the sales codes activated? 1000047484.jpg1000047485.jpg
Has anyone figured out the part number for the harness above the 12 pin?
Thanks
Looking to do the same. I have a 360 trailer camera kit already installed from my 3500. I've got a 1500 now that has the 360 trailer, trailer tpms etc active but no 12pin at the rear bumper. Trying to find the parts to add this to the rear bumper.
