Rebel on 295/70/18 bfg ko3
"That 105.7lb minus my 72.2 is a 33.5lb per corner" . yes, but don't forget you are on 20", that's 2" less side wall will make the lion sher of the weight difference. 20" wheel hinder offroad performence because of the shorter side wall.
Correct, however, if towing the 20's would be better since there is less sidewall to flex under load. So it is a good compromise if you tow and do mild off roading. If you aren't towing and want to off road there is no substitute for as much rubber between the ground and the rim as possible. So, 18's.
