2020 Ram Paint Issue on Roof
hayden536
Has anyone here had this kind of wear on their paint on such a new truck? Looks like I'll have to cover this out of my own pocket. Not sure why this would happen after only 5 years and regular washing.
I had this on my 1998 Dakota. It always looked like it was sandblasted while driving. I have ceramic coating on my truck now and it still looks great and it's a 2020.
@hayden536 - Do you take it through automatic washes?
I have 2020 that still looks great.
I am second owner bought Dec 2020 with 18k and now have 48k miles. I only hand wash - Never automatic wash. I also use Meguires Ultimate wax 2x/year. I'm in FL sun and do best to keep covered/shade when possible... but it gets more than average UV.
No auto washes, south FL sun and 60k miles. Everything else on the truck looks great except this one spot on the roof unfortunately.
Glad your truck is still looking good! Guess I'll have to get this spot repainted.
Wow. Sorry to hear of your issue. Thanks for confirming sun exposure and wash similar to mine... I'll watch my vehicle closer to see if this develops.
UV light has eaten the clear coat from that area which was probably thin to begin with. Since its the roof, I'd lightly wet sand it with 800 then 1500 then spray some automotive clear on it feathering the perimeter then wet sand it again with 1500 then polish
I can turn a wrench but have never done any paint work, is this as easy as it sounds, or should I take it to a body shop?
I worked at a body shop through college so to me, its releativley easy. I'm not saying you need to try to achieve a showcar repair, just knock the loose clear coat off then mask the area and apply some automive clear then buff to blend.
If your altrnative is a body shop then you attemting to repair it will not do anything the body shop could not undo if you chose them to repair which is the primary reason I'd try.
clear top coat
Simple how too although this is worse than yours
You could do iot yourself for less than $50 and a few hours, shop will probably make a job out of it and charge you at least $1,000. Where are you located, if you're close, I'll help you
clear top coat
Thanks so much man I'm down in South Florida, bit far from Texas but I may have to give it a go.
Worse case. You’re out some time and a little bit of money and you just pay a bodyshop to fix it . Worth the gamble.
clear top coat
Following up to say I DO NOT recommend the company mentioned here, automotivetouchup.com. I ordered their product using my VIN to match to their paint, saying they guaranteed a match. The paint I received is not even close, it is black while my truck is grey. They will not offer me a refund or a new paint as it has been over 30 days. I could've had a closer match by pulling a spray can off the shelf at Autozone. Avoid this company.
Sorry that happened to you, I've used them twice and their paint was a perfect match for me as it was for those that told me about it.
Maybe they gave you a mislabeled can or the wrong paint was put in the can, IDK.
