Stored code
Shane12
Got the Hemi tick repaired by dealership.Since then have had injector replaced in cylinder 3 but code continued to pop up.But today light turned itself off and it’s running fine.Dealership keeps saying just a stored code.Does this sound legit
disconnect battery overnight and then drive it around then check with scanner.
there should be no code if issue is fixed, not even stored one.
Thanks for reply.I turned light off it was fine light came back on but shut itself off .Should I just wait and see if it comes on again
