rear tail lights not working at night
martman00
My brake lights work. My Signal lights work. At nigh time, when I'm not braking or signaling, there are no "running lights". Ive tried replacing the brake light with a OEM bulb since it looks like it has double-duty at night time but no luck.
What else can I try? Will i need to replace the whole damn unit?
Thanks
Test the plug and see if you are getting power for the lights. Then you will need to track that down.
Would I be able to replace just the plug? If its a problem with the harness I think I'm pretty boned. I'm really not sure how to go about troubleshooting that or even getting to much physically.
Its freezing outside and I'm wondering if I'll need to tap out and go to a stealership basically.
Thanks
not sure how the taillights are wired since i have LED tail from factory, but maybe check the fuse too.
There is no fuse to check, power is supplied via the BCM. Most likely 2 culprits, the bulb (7743) or a loose plug. Did you have any work done before you noticed them not working?
Nope, no work done, no accidents, etc
i see. never actually looked into it
My left tail light quit working. Bulb and connections were good. Took it to a shop and found out the BCM needed to be reset; now it works. Makes me wonder what else will fail because of computer glitches.
Do you know how they did the reset?
Just throwing this out there. Are you turning your headlights on with the knob?
