SgtSlaughter
- Mar 9, 2025
Just installed FOX 883-06-166 coilovers and drove around the block with them. I noticed the CV axle is rubbing a good amount on the bottom of the coilover. Anyone else used these and had this issue? What might remedy this?
2022 Rebet DT with an ecodiesel, Fox coilovers set at factory spring height, Fabtech UCA with uniballs and energy polyurethane sway bar bushings on current setup.
