noise when turn right
Great job theblet! I will certainly do that...Thanks yet again brother..I'll let you know if it solves my problem 🤞
My 2021 Laramie just started doing the same slight vibration feel during slow speed right turns, its been driving me nuts trying to hunt down the cause. Been checking torque values all over my front suspension, checking bearings, tie rods, end links, etc but sounds like this TSB might be the silver bullet. Going to the dealer with the TSB in a few days. Finger crossed. Thanks.
There’s a power steering TSB for it. I hd the same thing. They flashed the computer and it fixed it.
So I'm here at the dealer and they are telling me it should already have this update. Cause it's not listed in my recalls or bulletins.
Having this issue as well. Gonna call my local dealer. Wonder if this is consider part of the drive train.
So got my truck back with the TSB done. so far so good. I'm unable to replicate it from before. Ill update this post if I spoke too soon.
Yea it’s not. But here’s the weird sound I’m talking about. Wondering if others are hearing this on this thread or is this thread a different issue?
The steering video
Hmmmm, I was hoping that your video would solve the noise at low turn that mine has, but mine sounds like a power steering pump issue while yours sounds like a zoo!
I might ask the stealership to do the flash anyhows when the truck goes back to have them fix the blowing manifolds. :rolleyes:
My noise seems to occur when turning into side streets at low speed with no braking and no throttle, experience from the distant past tells me that it is a similar noise to that of a low rpm issue starving the pump - but it's hard digging this stored stuff out of my old, abused brain after six years and 200k of trouble free motoring in a 2nd gen Tundra...
I've only had this beast a month and its a tad annoying to have a four year old truck that is throwing grief at me already. The stealership pointed out, quite gleefully I might add, that they had fixed a recall when they did their PDI before they put it on the forecourt.
