B Pillar Body Cushions
msnyder1112
Massillon, Ohio
Has anyone replaced the B pillar body cushions? Not the lower absorbers but the ones above the frame?
I’m just wondering if the process is the same as the A pillar cushions?
Loosen, lift, replace?
Exactly the same. Loosen mounts on both sides, remove bolts on one side only and lift the body enough to pull out the top of the mount.
One thing I did was after I replaced mine, I left the bolts somewhat loose and moved the truck to allow it to settle correctly without any binding. Then I torqued the bolts all around.
Thanks. Completed it. Very easy.
