Wind noise
OK, I put some packing tape across where the trim is at the top of the cab and ran it back about 8 inches and down several inches. I also placed some silicone under the trim and the noise stopped COMPLETELY even on a trip to Colorado. This is an air induced harmonic where the air gets under the trim and it vibrates. It happens to me around 70+ MPH and gets worse the faster I go, if there is a cross wind at a "perfect" angle its a constant whistle that will drive you crazy as you cant even have a conversation. I am going to have my body shop replace the trim and put some put some silicone or some other type of adhesive to stabilize this trim (It does move when you press on it and I can certainly see where air going under it would cause it to vibrate perfectly) I will do this in the next month or so and let everyone know what happens with the truck.
BTW
I just had the truck in the shop for other work and had them remove the tape and clean it up, the NOISE CAME BACK on my first trip down the highway...
2019 Limited with all of the trimmings
BigFootGreg
BTW
BigFootGreg
I'm very interested. Take some photos if you can.
Moved to this post:
I am having the same issue in my 2025 Laramie. I have noticed that when I am driving on the freeway, if I fold in the mirrors, the noise is almost gone (there is still some natural wind noise). I am not sure if it is the mirrors or if that is just changing the aerodynamics of the truck and, therefore, the flow around the window area.
Suggestions? and please no "Get a Chevy, get a Ford". I have had both and all manufactures have issues. Just real suggestions please?
Just had my first experience with wind noise. Fortunately it's NOT on my Ram, but my Ford explorer... However it may be relevant.
Just had my windshield replaced due to a crack. Prior to replacement it was quite as could be. Immediately after replacement - wind noise. This must be due to the gap between window and frame. I'm sure I can put something inconspicuous in there to test my theory, but I'll wait until it gets warmer out.
Sorry for the VERY slow response. I found 2 other threads where the users recorded the sound. I need to see if the have the same characteristics (it sounds like they do) if its the case, it "should" be addressed by RAM but we know how that's will go. I am going to order some new trim for the top of the cab and make sure its attached really well with some good adhesive. One thing I worry about is, if its the profile of the trim making the noise and not the trim itself.
The sound on mt truck is right around 622-650 Hz. You can see that by the attached picture below. The other sounds that you see are standard road noise that doesn't typically bother use as its NOT in our ear.
Bigfootgreg
Moved to this post:
Can you get a recording of this noise and post it here for me, let me know how fast you are going as well. I would really like to analyze it.
Bigfootgreg
