any ideas?
Hamco8520
Any ideas what's wrong here? There is another clunking sound in the front end only when i turned the wheel left to right. I seem to be breaking something every 6 months. I've gone through CV axles, tie rod ends, and struts in the last year or so. I appreciate y'all.
I would use chassis ears or a stethoscope for chasing it down.
is it lifted or stock height ?
Also if lifted since you're running Bilstein, are you also running a spacer on top for more lift? Max on these are 3-3.5. Anything over that you're binding the CV. Also you're not supposed to run a spacer on top of Bilstein, or any leveling strut.
