Wet floor
KINGFUROOK
So I know about the rear window leak and felt all along the frame, window, and along the vertical rear and side walls. Nothing is wet or shoes signs of ever haven been. That said the floor under the rear driver side seat is pretty wet. Any idea where this could be getting in? IMG_20250305_154433351.jpgIMG_20250305_154453488.jpgIMG_20250305_154514447.jpg
Whelp it is likely the rear vents. Should have searched first, but whatever. Here is your chance to say so 😀. Looking for the replacement part and will install asap.
The window frame could have cracked at the corner.Pull the seats and the back wall trim, hose the rear of the truck and see if you can get a visual on the leak.
Second though it may not be the rear vents. Water is only in the far corner. Hmmmmm
