295/70r18 BFG KO3 on 100% stock 2025 1500 Big Horn
Dana.Bovender
Just an FYI; fitb100% with zero scrub, rub or issue. 34.3 tall by 11 wide on stock 18” wheels and no leveling kit.
Did a small trot off road over some rutted areas, no problems with articulation. Note: not a diehard off roadie..
Pics below
Looks sweet, MPG before & after?
They look good on that truck, why are you parting with them?
Not parting with them, just put them on.
MPG- sadly I lost 1 mpg. I can live with that since it’s with 87 Octane, will try 89 or 91 to see if it makes any difference or sense economically. Have a station near me with zero additive fuel, may give their 87 a shot too
No, just 4x4
Wow! That’s surprising. I have the same size tires (Falken Wildpeaks) on my Backcountry with ORG and it looks like you have even more clearance than me.😲
Pics below
What is the actual numbers on the tire?.. 285/75?
@Dana.Bovender, looks great! Simple, clean, capable-looking. Thanks for the excellent photography as well, very thorough and clear, tells the story well.
Maybe some day you'll add your truck's particulars to your signature?
Thanks, it’s a bone stock 3.6 V6.
Nothing fancy just 4WD
I’ve got to find time to build a little profile data….
What width does your tire actually measure? You said 11" the specs show 11.8, I'm looking at geolander a/t xd's with the same width but I'm concerned about clearance with the UCA as I currently have about 3/4" with the stock 10.5 wide tires
Technically tread width they are 11.25, on an 8” rim. I had the same size tires on a Ranger with an 8.5” rim and widest point on sidewall was 11.75. I believe that is what they measure, but I don’t know for certain. Tread width is just over 11” maybe by 1/8- 1/4”
Thanks for sharing your setup and pics!
I have the same OEM wheels on my 2025 Warlock and have been wanting to change it up to 295/70r18 Toyo ATIII with 18x9 Method 318. There's an option of 0 and +18 offset. Anyone know if the wider wheel and/or different offset would make that big of a clearance difference?
BFG KO2s run notoriously small. Coming from a Jeep Gladiator, you will find tons of posts about them running small compared to their stated size.
