Pro Comp lift?
Monster8842
So I'm shopping for a lift kit and came across a Pro-Comp 6" lift part number K2103T on amazon for under $500. I am skeptical and curious about this. Has anyone used this lift and if so would you recommend it?
Pro Comp is pretty much the Walmart of off road. I would even rank RC higher. It's cheap for a reason.
A lesson I learned from the Jeep world is you get the quality you pay for with Lifts. Cheap lifts are cheap for a reason, and that reason always ends up more expensive.
Also…no idea if this applies to rams or not. But anything over 2in of lift will need substantial modifications to realign all components and ride quality. Front/rear track bars / sway bar extensions / uca replacement / drive shaft realignment / ect.
so thoroughly research what ever can you want before you open it and find the worms.
