Dxlatos
- Oct 3, 2023
Hello All,
I've seen numerous threads on this forum about the failures of the air ride in cold climates, but I am not sure what is expected in cold weather versus what is actually an issue.
I have a 21 Ram 1500 Limited and I've had it about 2 years. In that time I haven't had any issues with the air ride, or any sag/frequent run of the compressor.
In the last week it has been very cold here, (-30F was the lowest) and the truck has been outside a bit more than usual. When it sits outside in the cold, I find that in the morning one, or both rear corners will be sagged. However after a warmup it will air up and drive without issue, that was, until this weekend when after sitting out in said -30F overnight, the next day I got two warning messages on the dash. One about the air system cooling down and one about "immediate service required" for the air system. At this point the truck said that it was in normal ride height but would not allow for changes of height.
After an hour or so warm up and being driven around the errors went away and the truck again moves up and down. It seems to hold air, the compressor isn't running frequently or anything. Parking in the garage overnight and there's no issue the next day, but it had to be outdoors again overnight last night and this morning it gave the "Payload exceeded" error, again until the truck was warmed up.
Is this just usual behavior of the system being really really cold? When its parked indoors (not a heated garage, but certainly warmer than outside) it seems to hold pressure in the bags just fine, it seems to only be when exposed to the really cold weather directly overnight that its having issues, and even then only until it warms up. I guess what I am asking of the community, does this sound like an issue or something I need to spend time+money investigating or is this just simply a geographical issue and I need to let it warm up?
Thanks in advance!
Thanks in advance!
