anyone know how to reassemble a nilight rocker switch?
saylor
so i did a dumb and broke my nilight sasquatch rocker switch . .I thought the side clips came loose and you mount the switch base then click the front cover onto it. . it doesnt work that way, and now i have 4 springs and a contact plate loose in my hand and a not springy switch...
anyone know how they go back together? or did i just get an opportunity to buy another switch?
in a moment of fkn wylie E coyote supra genius i think i figured it out
pic in case you are reading this hoping to do the same because you took apart your nilight sasquatch toggle switch light bar switch
the metal plate lays in the cavity sort of on top of a metal piece in there that lets it rock, then there is a small notch for where each spring goes.
Hey so I put mine back together but now it won’t turn off
likely you mixed up the power supply and the powered trigger. swap them around and see what happens.
