Mysterious clunk and squeak in my 5th gen ram
I got a 2019 ram 1500 limited. Sadly, it has this clunk sound when going over potholes and bumps at lower speeds. It’s also accompanied by a squeak too. My dad and I have replaced almost everything in the suspension. Sway bar bushings, links, air struts(which took forever to arrive) CV axles. Hell, even the whole front differential was replaced. Even with all those things, it still has this clunk. And to make it worse, it sounds horrible when it’s cold outside, but sounds less when the truck is ran and warmed up. Pls 5th gen ram owners, help me find a solution!! I’m going crazy over this damn sound!!!
Weirdly, the clunk is only heard on the inside of the truck. Where the foot well is
I have the exact same problem. Can only hear it from inside where the foot well is, just like yours. I replaced body mounts, sway bar bushing and end links. Drive me crazy as well. Have you found out what it was?
