Battery drain issues
I have a 2025 Longhorn with just over 3000 miles on it. Went out to start it one morning and battery was completely dead. Bring to local dealer can’t find anything wrong, 2 weeks later same issue. Have it at a the shop I bought it from now hearing the same story that everything seems fine. Not sure what to do 🤷‍♂️
Yes. In my case it was a less than perfect connection at the driver side fender main ground, next to the hood hinge.
I cleaned it really good and applied conductive silver grease to keep it from getting oxidized again, knock on wood, been good since Jan 20 2022.
How did you find it? I would imagine there a tons of places with ground wires throughout the truck
It is the main grounding point from the battery to the truck, so checked it first and got lucky.
As far as troubleshooting it, I used a multi-meter from the negative battery post to the ground stud and measured 0.1 volt drop between the two points.
Also remembered seeing the TSB about a poor connection possibly causing issues.
Yes, there are around 30 or so ground connections in all.
Thanks, I also have a clamp meter I used on my boat to track/mesure DC amp draws for a multitude of things. I wish we had a schmatic and/or pictures of all those ground connections on this truck. Before my 24 limited went in for a new engine (yes, ugh with only 7100 miles), I noticed the battery was just below 12 volts. I keep track of its voltage since new and it has never been below 12.3 (that was after 3 weeks of sitting this past summer). So because I’m sure the mechanic will only focus on the engine, I’m kind of expecting something like what you describe after getting it back next week…I’ve got a jump pack regardless.
This is on my 2019. You can get model year specific by subscribing to Alldatadiy for not much money.
These do not crop and retain resolution all that well when posting here but should give you an idea of what info is available.
We just bought a 2025 RAM 1500 Limited, 600miles. Same problem with battery dying. At dealer since Thursday PM. They were able to tell there is a drain, but can't find it, working with engineers/manufacturer. Did any of you get resolution to your battery draining? Or was it a problem with charging system?
See this video I took from my 2025 Big horn Hurricane engne, after I disconnected the batteries and then re-connected. You hear moving electronic parts, then a whining sound until I pull the neg battery lead. You may have to turn up the volume. I'll try to get a better video with louder sound. Any ideas ?
So there’s no solution yet. I’m having same problem too. I would charge it to full, start no problem. If I jumpstart, it runs fine but turn it off and back on, it struggle to crank on.
This same scenario has happened to my 2025 Rebel again this morning for the 2nd time in less than 1100 miles.
I have a 2025 RAM 1500 and am having battery drain issues as well. Today, on cold start, the voltage reading system showed below 8 volts, but once engine started alternator recharged it to 14+ volts. Took it to the dealer, they connected their computer and said there are no issues. Once it warms up a little, I plan on pulling fuses to try to diagnose drain issue. I appreciate all the insights shared to date.
That link is a dead end for me.
Been meaning to post on this as I think I found a fix. RF hub wasn’t the issue. I replaced the can bus star connector located behind the panel to the left of the steering wheel. ~$70 fix you can do yourself. Just pull the pins out of the old one, one by one, and place into the new one. Haven’t had battery drain or electrical issues for 2 months now.
Had a daily parasitic battery drain. Dealership would test then recommend I replace a module. Replaced the rf hub, still drained, replaced the radio/screen, still draining, then they recommended a complete wiring harness replacement, which I didn’t do. My dash warning lights and cluster began lighting up like a Xmas tree, truck randomly responded to the key fob, and still draining the battery. When I tested the battery the source of draw was inconsistent. This led me to believe it’s a network connection issue and not specific modules causing the problem. Found a couple videos online that hinted at the same thing and from various Stellantis brands so I figured for $70 it was worth a try.
Before you go to the dealership,1.) watch the videos below, 2.) buy a cheap OBD reader and see what codes it throws (wish I did this sooner). If it has lots of lost comms codes I bet your looking at a network issue and not a module failing issue. Super easy to use and pairs to an app on your phone (links below). Either way you have documentation to push them to look into it. Mine was throwing tons of these codes when the dealership initially scanned it and they ignored them. I asked for the reports after their suggested module fixes did nothing, well other than costing me $1k, time, frustration, etc. , and began diagnosing myself. I’m not a mechanic, just someone who hates being taken advantage of. For $160 on the reader and replacement part you break even for what the dealership charges for one “diagnosis” fee.
Dealerships are not looking to diagnose a cure. They recommend bandaids for problems for the exact reason you stated…replacement of modules to make a ton of money on parts and labor. IMO, cars are engineered this way to ensure failures and retain incoming revenue from you after the sale.
Star Connector Can bus: 2017-2025 Mopar Connector Can Buss 68321746AA | Mopar Online Parts
OBD reader: Amazon.com
I have a 2025 1500 Bighorn. Noticed that the dash stays lit several hours after turning the truck off. I unplugged the battery and now I have a check engine light with code P068A. If the truck is off in the run position the battery voltage is 12.7v and flashing red. Truck is brand new picked it up last night 180 miles
Did your P068A code go away on its own? I just had an amp, subs and secondary battery installed (for the amp) and I have this same code now. The shop said that it’ll go away on its own after a few drive cycles….hopefully they are right.
