Please clean your front sensors???
Paco
I installed a New Brake Booster from a wrecked Limited eco diesel.(same year 2022).
Updated all the stuff in Alpha.
Couple weeks ago dealership did Brake Booster recall.
Now once in a while a Loud ringing goes off for several minutes: It tells me to clean from sensors.??/
I am assuming since I dont have front sensors on my Rebel, thats why its doing what its doing.
Is there some way to shut off the ringing???.
It does not give me a code, but its going to cause me to loose my hearing if I cant shut it off.
Help.
Help.
You don't have parking sensors in the front bumper or the buttons on the center stack? I thought that was standard. You could use AlfaOBD to disable them if you don't have them. I'm not sure why they all of sudden enabled on their own.
I think it has to do with the ABS module swap.
I think when the dealership did the brake booster flash, it saw I had a Limited model ABS and updated the software for a Limited model that has front sensors???.
I think when it updated it also added a few things from the limited into my Rebel, getting pretty weird LOL.
Hope that makes sense.
Like advised, go into Alfa OBD and check if tit is enabled, and if so, disable
15 below zero right now. Will check out tomorrow.
Thanks.
