Lockable console
Nightowl
I’ve been thinking about getting a lockable console safe. Any recommendations?
This one has been mentioned on this forum quite a bit.
Lockerdown unit here but it appears they’re no longer in business. Console vault looks very similar.. spurge and get the electronic lock.
I have a 2023 Limited and I've been considering getting a lockable console safe.
A lot of models are dependent on trim level. Anyone fit one in a Limited?
When I look at Console Vault, they have two types (regular size and a low profile one). Where do I measure the max fill height? Is it the deepest part of the console tray to the height of the sliding cup holder?
Thanks in advance.
Just curious if anyone has fit a Console Vault low profile with electronic key pad into the center console of a Limited.
Based on what I can tell, the key only will fit but the electronic lock version sticks up a little higher.
FWIW id avoid anything electronic with locks…eventually the battery will die and murphy will be sure it happens when its least convenient. A traditional key or 3 number combo lock will probably serve you best.
Throw a spare battery in the glovebox.
Not all locks can have the battery changed from the outside 🤷‍♂️
To each their own, just offering some perspective.
This one does And just swap it out once a year along with your keyfob battery
Lock'er Down is no longer in business. Here is a similar one from Console Vault, low profile.
You replace your keyfob battery every year? Then there's something wrong with it. Mine's 4 years old and still going strong.
No, theres nothing wrong with it, I’ve replaced it 2x since new simply because Ive swapped to a AJT Design case 2x and did it while It was apart.
But I also keep a spare battery inside the glovebox.
Biometric safe with rechargeable battery, 6 digit pin, key, access by phone app. Tray slides over it fine. Biometric is incredible.
@dieselgrin: So you have a Limited? What brand of safe do you have with the biometric access?
I'd like to get something like for my Limited. Console Vault makes one for the Ram Limited but only the low profile safe (key only) version. Thanks in advance.
Hi Diesel - I also just purchased a used 5th gen (2019 Limited) and am looking to get a safe in there as one of my first mods. A few questions for you:
Is this the exact one you purchased?
How did you secure it to the vehicle?
Lastly, do you have a limited/longhorn trim that has less room for the safe?
Thanks in advance!
