18” wheels on 2022 Limited Longhorn
Wifuop60
Is there a definitive list on what aftermarket 18” will clear the brake calipers? Is there a inside diameter measurement which is the minimum for clearance?
Looking to get off the 22” wheels.
I’m not sure measurements but you can go to custom offsets and look at their extensive gallery with 5th gen’s running 18’s
Just ditched my 20-inch stock rims for Method 18x9's and had the same issue. The calipers barely cleared and had to be cleaned up because the casting wasn't done very well and left a glob.
I’ve got Fuel 18x9 +1mm in my 2021 Longhorn and they fit with no problem, other than you have to be careful about balancing weight placement. I will note, though, that my truck originally had 20” wheels. My understanding is the steering knuckle on Ram’s with 22” wheels is different, but I don’t know if this makes any difference with aftermarket wheel fitment.
What offset did you get on the Methods?
That's what I ended up with as well. No caliper clearance issues. I bought the wheels and tires from Tire Rack and they have a note for this application to position the weights carefully
