RF hub failed - now I know
My truck is a 2020 Ram 1500. a few months ago I had the leaking back window. I bought the truck used, and it only came with one key fob.
I’m only aware of this because one day the truck wouldn’t start. I even hooked up jumper cables thinking the battery was dead, and when I hit the PTS button, still just a single click.
Pulled my phone out and did some searching and this is when I discovered the massive amount of people having this same problem because the leaks and possible water damage to the RF Hub.
I have no clue how long the back window had been leaking?? I noticed several cracks in the plastic frame that the back window mounts in to make the seal.
Through some determination, trying multiple times cycling through the PTS ignition buttons and locking/unlocking the doors with both the buttons on the door and key fob, pushing the PTS button with the fob itself, I was able to get it to start.
After that, no issues for a while, but I made an appointment at the dealer, anyway. Went ahead and bought a new battery for the FOB and had the truck battery replaced, as well, as it was getting low.
Took it to the dealer, they said the only thing covered by the warranty was the 3rd brake light seal. So, they replaced that.
They said the window and window frame isn’t covered, and I would need to have that replaced at my cost.
At this time, they said there are no other issues with the truck, they checked the systems and everything came back good.
I did not have the back window or frame replaced, instead, I sealed it myself with black sealant. Checked after words and multiple times since then to verify there is no leaks around the window.
Unless you know its there and get close and look in the gaps, you can’t even see it. $8 of sealant was way easier to swallow than $1200 for the window replacement.
BUT! Over the last several weeks the not starting while pushing the PTS button. I have always been successful at finally getting it to start using the same methods as before.
I don’t know what actually causes it to eventually work, I just know it eventually starts. Sometimes after just a minute or 2 or sometimes it takes up to 15-20 minutes of….determination?
But the issue is definitely becoming more frequent.
So, I had another appointment at the dealer to specifically check the RF Hub for water damage because the truck would just randomly not start.
They said they checked everything and all the communication systems and everything seems to be working fine. They also checked my key fob.
They think the issue is my key fob. They say it’s only transmitting intermittently at a success rate of about 40%.
The guy showed me the checker and how they check it, and it does appear that it’s not working as it should.
So, they quoted a new fob for $244 + $80 to program it. On top of the $238 diagnostic fee.
I did not go with this option. Instead, I chose to order one online.
I’m still highly skeptical that they key fob is actually the issue, but I’m trying it anyway because if it is, GREAT, and I needed a 2nd fob anyway.
It always locks and unlocks the truck fine. The dealer says they are like 97% sure it’s the fob and that the communications systems are fine.
They did this assessment in about 25 minutes, so I have my doubts they actually physically checked the RF hub for signs of water damage.
Does anyone have any suggestions or insights?
Because yours at least clicks when you push the start button, you might be chasing the wrong rabbit here. Were you able to unlock the doors with the fob? When ours died the truck was completely dead. I couldn't even unlock the doors. Once I actually got into the truck (after several attempts to disable the alarm) using the key inside the fob, there were zero signs of life, alarm aside. Pushing the start button did nothing. No clicks. No dash lights. No interior lights. Pushing the button with the fob did nothing as well.
Since yours clicks when you push the start button I would suspect it's something other than the RF hub, such as the starter. Those are more likely to become intermittent when they start to fail.
When my hub failed it was literally dead. Nothing clicked squeaked or groaned. When the hub is dead the truck is useless.
2025 Lonestar with 11,586 miles on it. Just had this happen to me last night. Stopped at a gas station for a drink, got out locked the door. When I came back the fob wouldn't unlock the door, used the key to unlock the driver's door and the alarm went off. Tried numerous times with the fob to the PTS absolutely no response. Over 30 minutes of trying, the head unit did power up briefly once in that time. Towed it to the dealer last night, will see if they check it today...
Went to get in my truck Sunday morning and the keys wouldn't unlock it. Fobs would not open the doors and it seemed dead. I used my manual key to open the doors and the alarm went off. I soon popped the hood and disconnected the battery to stop the alarm. I had to move it out of the way of my other car in the garage so I disengaged the trans from Park with the lever under the ebrake under the panel. I pushed it out of the way and tried a few more battery connects and disconnects to no avail, the alarm kept sounding and my fobs didnt work. Long story longer, I took my battery out and had it tested and it was good. After leaving the battery disconnected overnight I decided to try it one more time Monday morning and the alarm reset and my fob worked and the Ram started. But it ran for about 30 seconds then shut off and the keys didnt work again. Sheesh. Finally got it towed to the dealer and they found the RF hub is failed. No water intrusion just flat failed.
What a disaster of a design in my mind. What if this happened to someone off-road? I don't know what the design should be but sure isn't it. I also just took a long road trip to SC and am so glad it happened in my driveway, not out during my trip with my family in the truck.
Thoughts?
The exact same thing happened to me. 2022 truck. Tried every hack out there.
I had no leak, but did look at the black box the RF hub is in. To be honest both moisture and dust can easily get into it. After the shop replaces it I am thinking of sealing it with some silicon. It is a very worrying issue considering I am often driving to remote places.
Well as you have gathered, the vast majority of these fail from water intrusion. I suppose it's possible for it to naturally fail, but unlikely. They thought mine was a natural failure and replaced it that way under warranty, HOWEVER as it turns out I found out later it was from water leaking through my rear window upper outer frame. Because it happened again and the water had been leaking since well before the first failed hub.
I bagged mine. Just leaving the bottom open for air. Mine is still bone dry and new but I also ran silicone along outside rear .
Well, after 3 weeks (12 days of which the dealer didn't touch it) I picked my truck up and of all things the horn doesn't work now. It worked when it was dropped off because the alarm was going off and beeping constantly when I would open the door...
Apparently they pulled the fuse when they moved it out of the way to have it sir for 2 weeks...
I just joined the forum so I could see pics of RF Hub. I'm also in the middle of replacement at a dealership because truck security locked me out, apparently, like a lot of other Ram owners! I bought a used 2022 1500 Laramie last year and it's been a nice truck...but this RF Hub business (and idiotic placement of it) is worrying me. Dealer called today and said truck is ready...couldn't find any leak??? Hmm, but RF was fried. Out of warranty period, of course. Anyhow, thanks for pictures and I'm wondering if seat has to be completely removed to get to Hub?
Yes, you need to remove the seat.
For what it's worth, I've gone through the 20 different phone numbers to get to Stellantis and got a guy to put info into system to "try" to get the ball rolling on a recall. I told him that they could do recalls and put a damned baggy over the Hub or they could wind up paying $millions when it locks somebody up while they're driving! I think a lot of Ram owners need to pester these people and maybe, eventually, something might happen? I'm seeing way too many folks with this same problem. Seriously, what imbecile thought this was a good spot to put an RF Hub (which seems to have exposed wiring behind it)?!!
The real problem is the leaking rear window not the location of the hub IMO. If they could resolve it so the windows don't leak in the first place, problem solved. My replacement window from Safelite was installed and sealed correctly and is not cracking either so my problem seems solved.
I want to agree with you, and I would if they didn't offer sliding rear windows. But the fact that an owner can open the rear window and then forget it's open leaves electronic devices on the rear wall vulnerable to water if that happens before a rain storm. Granted, that would be the owner's fault for forgetting to close it, and my wife is one of the worst offenders for that lol, but the fact that it can happen means they should have either protected it better or located it in a safer location.
Agree but issue is also no weep holes in window track, like gen 4. Because if window doesn’t leak, or brake light or shark fin rubber on slider will dry out. To answer other guy question reasons they dont find leak is because water flow in track down power slider cable to power slider motor and drip out bottom of motor on to rf, if its rubber on slider no leak seen
Fair enough.
Bah, Mines in for the same issue... When the tow truck dropped off I told the dealer it was probably the RF hub, they told me no, that can't be it because it hasn't rained recently..., kept telling me "it's the battery", then when the tow truck (that was Ram Roadside) told him he tried to jump it... the Advisor was saying "oh you did this, you must of connected your jumper wrong and blew it up).
Then he saw I had replaced my battery last year with (heaven forbid) a Walmart AGM (which is made by the same company (Clarios) as the Mopar batteries are... and blamed that.
So I have a CPO, and a "wrap" warranty (covers everything else the CPO (mostly CPO is drivetrain) doesn't until 7/100)... they called me the next day and asked for another $289 (on top of the $250 I had to authorize on drop off to "diagnose") authorization to "remove the back seat to get to a module they believe failed"). So... it's the RF Hub...
$289 to remove the seat, which takes what? I minute or two, I've done it myself... it's not hard at all.
They also told me it won't be covered under warranty... had to tell them again that I gave them a copy of my wrap warranty (Portfolio Elite)... it's covered, call them.
Now it's a day later, can't get ahold of them for an update. Their app (AutoNation) says it's been "checked in - awaiting diagnosis to begin" for 2 days...
No loaners, no rental, hell, they wouldn't even give me a ride home (which is a mile away).
I bought the truck from another Ram Dealer 40 Miles away, night and day difference in service.
But this truck now has had it's rear diff rebuilt, water pump replaced... rear glass replaced, and now this module... been in the shop already 4 weeks in over 2 years I've owned it.
Really questioning if it's worth it, especially when the local dealer is impossible to get a rental through. Today in fact I had to take a day off as my wife needed to go to the Doctor... so she needed her car today.
Bah, just frustrated... like the truck, but it seems like a lot of issues for 60K...
Would this be the same RF module to replace if my TPMS sensors are failing? I'd hate to have to get new keys and get it programmed for just a tpms module. It's not the sensors/batteries bc a different tire will show each time I turn on the truck its just random as to which tire but I hate having the check engine light on and not knowing the condition of my tires while in the truck.
The RF hub is the receiver for the TPMS.
Not saying that the hub is not failing, but...
My money would be on the sensors causing this. How old are they? Normally supposed to last from 5 to 7 years.
I replaced two of my sensors that were dropping out randomly, caused by failing batteries, with OEM Mopar. No problem`s, worked as designed.
Then few months later, the remaining two sensor`s batteries failed. Replaced them with chinese made units from amazon.
A mistake, now the system is randomly unable to tell what tire is in what location tripping the TPMS notification.
  • Sad
Reactions: c3k
