Eibach or Bilstein
Gibster
I am sure I missed this in the search somewhere! I have a 2023 Rebel GT I want to level so I can eventually put bigger tires on it. My thought at this point is to use my current springs and just purchase the shocks. Based on your personal usage/opinion, sell me on either the Eibachs or the Bilstein 5100s. Lastly, would this all me to run the metric 34/35s without rubbing? Open to all other constructive opinions/ideas I might not be thinking about. Thanks!!!
Both terrific options. Can’t go wrong.
I’ve had both the 5100s and the Eibachs on the same truck. Both are better than stock.
Note: I have the coilover version of the Eibachs, not the one that re-uses the stock spring. So I can’t say for certain about those.
But assuming both Eibachs have a similar character, I’d ask this:
- Do you like to “feel” the road?
- Will you be doing more spirited driving / corner carving?
- Which is more important to you: responsive handling or comfortable & compliant ride?
Thank you for your help and information.
Absolutely. Where I was going with the questions was essentially Bilstien has the edge in handling and responsiveness, while the Eibachs have the edge in ride comfort.
They are not polar opposites; rather, that is just where each excels over the other. And they both handle better than stock.
The EIbachs run EXTREMELY stiff on my truck. I am used to driving sports cars with very stiff suspension, but this is something else. it sounds/feels like my truck is going to shake apart going over some rough roads.
