You have the 5.7 Hemi?Not much worse then stock. I'm around 15 now combined.
Wheels are 33lbs each...+ 66lbs tires.
I was wrong by 9lbs ..
Also my OEM were 265/70/18 so not a huge difference if not the same...
You have rebel with 20s OEM?
Oh yeah I agree definitely. I had bighorn with 20s prior to rebel and I wouldn't change the wheel setup no matter what. Perfect balance.Ah yes, I stand corrected.
I originally thought you had the MR605s..which are 7lbs heavier than your MR305s.
I'm a 2024 Laramie G/T..with 20s.
I've debated dropping down to 18s, but am probably going Fuel Variant 20x9-01mm at 29lbs and 275/60R20 Firestone Destination AT2s at 42lbs..which will be 1" taller than OEM, but exactly the same weight asOEM (actually a half pound less).
NOT as BOSS as your setup, but my mainly on-road usage works best with this..for now![]()
I'm level-lifted on Eibachs..your setup would fit..I just can't sell myself on the higher weight.Oh yeah I agree definitely. I had bighorn with 20s prior to rebel and I wouldn't change the wheel setup no matter what. Perfect balance.
I don't think you can even fit this in non rebel.
I wouldn't too...rebel is different so it doesn't matter that much...I'm level-lifted on Eibachs..your setup would fit..I just can't sell myself on the higher weight.
Great Look. I will be going with 34 inch K03s as well. The hidden wench as well. Did you put that on or hire someone to do it?All stock except wheels.
Definitely recommend new ko3 as I tested them in snow and I'm impressed View attachment 195093
