5.7 Hemi Coolant Leak from top of exhaust manifold driver side
Vmcr1
Hello all, recently I found a coolant trail and upon further inspection from the bottom, the leak comes from the driver side it is coolant leaking out but it is from the area where the head meets the block I’m sure it’s the head gasket but haven’t heard this being common, truck is a 2019 but only has 55k miles… any recommendations or ideas?
HAVE YOU HAD THE WATER PUMP CHANGED? I HAD MINE CHANGED 2 MONTHS AGO AND IT FREAKED ME OUT BECUASE I ALSO TRACED MY LEAK AND COULD SWEAR IT WAS COMING FROM BLOCK BUT TURNED OUT TO JUST BE THE WATER PUMP (WORN SEAL/GASKET) I HAVE 100K BUT 1ST WATER PUMP WAS CHANGED AT 60K
Very interesting result there I’ll check out the pump later I’m hoping that’s the cause and not the head gasket.
