Blind Spot Monitoring Module - Plug and Play replacement?
slatersan
Hi all,
Anyone now if these are plug and play or if they need to be flashed/programmed by a dealer when replaced?
Cracked taillight and condensation ( hopefully) causing blind spot monitoring alert, screen to go black, front windows to not work, and heat to turn on by itself.
Thanks!
Hi all,
Thanks!
It is plug and play on the taillights.
Nice. Thank you! I keep seeing the modules on ebay, looking like OEM part, with notes that say "Needs to be programmed"
Nice. Thank you! I keep seeing the modules on ebay, looking like OEW part, with notes that say "Needs to be programmed"
If you go to this post, it explains how to add it BSM. That would give you some idea of what needs done.
Thanks. Still apply if Im just removing the old module and replacing it with new/like?
Yes, that's shouldn't be an issue. The PDF document on that post explains everything about it. It's not tied to your Vin so you should be fine.
Hi all,
Thanks!
Did this fix it? Im currently having same issue.
