Will this fit?
1BADRAMLIMITED
Oklahoma
Found a good deal local to me for a OE Ram bed extender and wonder if this will fit or only designed for Rambox equipped trucks?
I’m not to worried about using it as a bed divider rather an extender (pivot)
Also I do under stand I’ll need to install the mounts or latches. But if you have done this and have pn#’s I’d appreciate those.
Thanks for help in advance!
I'm pretty sure the tailgates are the same on ram box trucks and regular ones, so it should work as a bed extender. It will not work as bed divider since the bed will be wider without ram boxes. You just need to order the mounts like I did for my truck. I was surprised the truck didn't come with them; I bought mine new.
Parts you'll need: 2- #68054996AA - Handle-Swivel Release & 2- #68054997AB - Inner Panel Grommet
I Paid $90.00 for these parts, but that was back in 2018.
That will only work on a truck with the Rambox option. Even if you buy the mounting pegs there is no place on a non Rambox bed to install them.
Does it not install on the inside jam of the tailgate?
I'm looking for same thing. I think this might be what we need.
Not sure about the side panels in the bed - I think I saw another thread about this. Still looking.
Yes those are it.
I’m not interested in using it as a divider but as an extension
My experience with non-rambox beds is limited to 4th gens, so I guess I can't say for sure on a 5th gen since we've only owned them with the Rambox option. Since the Rambox bed dividers/extenders for 4th and 5th gens are virtually the same I am making an assumption about 5th gen non-Rambox beds. If the non-Rambox beds are the same in this area then they will work, but I suspect the bed structure in this area is different...
