Laramie interior swap?
Nathan8856
Loving my 2025 Warlock, I recently got a really good deal on a set of Laramie seats and center console. I ordered brackets for the center console and rear seats. Today I decided to swap the front two seats in. I disconnected my battery and everything was plug and play all seat functions worked. I turned my truck on, airbag light comes on, screen doesn’t work, check engine light came on, odometer was flashing, wipers came on even though they were in the off position.
Obviously the truck was not happy!
I put my factory seats back in and all the issues went away. Does anyone have experience with this? Is there a way I can flash the computer so that it will properly communicate with the new seats?
don't you have to tell the computer the changes you made
lets see what
@Jimmy07
says
I’ll keep this thread updated with any info I can come up with just for a reference for anyone else looking to do something similar. I am going to look over my donor seats for any loose connections or anything that looks out of place.
depending what year the interior came out that might be the issue i know for the 25 model year they changed the module communication type. on the 19-24 their is a heated/ cooled seat module attached to the pass. seat and a memory module attached to the driver.
That's odd, are the seats from a 2025? Only issue I had was the flashing odometer which there isn't a fix for yet. I installed 2025 Limited seats on mine and that was the only issue I had. I removed them, not because of that though, but if I end up keeping this truck, they are going back on.
