Help: Leaking front axle and lurching on snow in 4High
Arya
2021 2500 6.7L with 77k miles
Two main concerns:
- First, the front axle is leaking slightly (see pics) at this “box”, anyone know what it is? Doesn’t seem to be leaking much as I haven’t seen any puddles beneath the truck but it’s noticeable. Is it a cause for concern?
- Second, when in 4 High and on very snowy roads, the truck lurches heavily when turning more than about 25% in any direction, is this common? I’m new to solid front axles and understand the front/rear diffs bind when steering, causing a lurch, but I expected that to happen only on dry pavement. I’m getting the jumping/jerking/lurching in snowy icy parking lots.
Thanks in advance!
Two main concerns:
Thanks in advance!
You might have better luck in the Homepage - HD Rams forum. This is the 5th Gen 1500 Rams site.
On your second question, yes, that's common because of the way 4WD works.
The first appears the be the 'front axle disconnect', similar to what Jeep uses on the Wranglers. Probably needs a re-seal. Might as well do a diff service at the same time. As for your second, welcome to the world of 'real' transfer cases.
