Small Rear End Lift?
DeanM2
I have a 2023 BigHorn with a Bilstein Strut (front) level-lift. After about a year, the rear end has gone down about an inch. And I am now doing rare carrying of cargo in the rear. Don't do any off-roading. I am very happy with the ride of the current suspension, BUT, on rare occasion (unloaded truck bed) on the freeway I will find a section of road that causes the rear end to bounce a bit. Every time I go throught that section of road, it will bounce. While annoying, that is rare, so I don't want to increase the bounciness of the rear suspension for most driving.
So I would like to accomplish 2 things. 1) Raise the rear-end up an inch or so to level the truck for the 99% of the time when I am not carrying anything in the bed. And do it in a way that does not screw-up the generally nice ride I have now. And 2) be able to temporarily put a thousand pounds or so in the bed without sagging several inches.
I am thinking that I can add Spacers under the rear springs to level the vehicle. And I'm thinking that I can add something like Air Lift air bags inside the rear springs to handle the occasional heavy load. Does that sound correct? Can I use the air bags to also level the truck (without using the Spacers) without damaging the ride quality? Or should I put in Spacers to level the ride AND air bags, and keep no air in the air bags until I am carrying a load? Your thoughts on Spacer and Air Bag companies is appreciated.
I am thinking that I can add Spacers under the rear springs to level the vehicle. And I thinking that I can add something like Air Lift air bags inside the rear springs to handle the occasional heavy load. Does that sound correct? Can I use the air bags to also level the truck (without using the Spacers) without damaging the ride quality? Or should I put in Spacers to level the ride AND air bags, and keep no air in the air bags until I am carrying a load? Your thoughts on Spacer and Air Bag companies is appreciated.
Only way you can use airbags to lift the rear is if you do a complete airbag set up that replaces your coil springs.
You can install lift springs and Bilstien shocks designed for lifted suspension. Ride quality won't suffer much if any.
I have a 1" spacer on my rear coil. Still seems to ride okay, but will probably be replacing with taller coil springs next year to get rid of the spacer.
1" spacer will work..Airlift bags will be helpful to fill when towing.
A really easy fix that can have same as OEM ride-quality would be to swap your rear springs for the ORP/ORG springs which are 1" lift springs compared to your OEM Bighorn springs.
I did this on the Front of my 2024 Laramie when I put Eibach struts on...1" ORP spring on Eibach strut on Clip #2 (0.6" lift) to get 1.6" level lift on my Larry. The ORP was exactly 1" as expected...and ride was still almost OEM...the Eibachs are stiffer valved than OEM struts.
Check the Part Number on your current springs and use this chart to cross-reference to the ORP springs (sorry, the yellow highlights were for my springs).....
I have Airlift bags in my back coils..I keep them at 3-5 psi and can't really tell you there are even there normally. I've juiced them to 10 lbs and don't believe they really lifted the truck at all, just kept it from squatting.
I think if you want a constant, static 1" lift, I'd just spacers or ORP coils.
You're supposed to go to 20psi for towing and hauling. 5psi is for normal use.
Yep, I'm just saying for daily driving you'd stay at 5 psi normally, but if DeanM2 is trying to use Airlift Coil Bags to get 1" lift, that's gonna take maximum psi and not really work.
Airlift Coil Bags are great for taking up squat, but not for full-time lift.
The Coils replacement Bags could do that..I just prefer lift coils and airbags for closest to OEM ride quality.
Many ways to go about it..I think DeanM2 is looking for something similar to what I've done..could be wrong though🤷‍♂️
I'll have to try pumping the bags to max 35 psi and see what happens sometime..I suspect they'll lift the truck a bit, but become very tipsy.
From what I have read elsewhere, the Air Lift Coil Bags that fit inside the coil spring do not actually "lift" the truck, they just keep it from sagging. Rather than expanding lengthwise, the air bags expand in diameter. They then squish the air bag out between the coils, and this keeps the coils from compressing. As a result, for a load, you need to add air to them BEFORE you add the load, or the coil springs would already be compressed and the air bags would not be able to properly squish between them to prevent the coils from compressing.
In my case, since my coils are already compressed by about an inch, I was thinking that I would raise the back end of my truck up to (or slightly above) the height I want, and then put some air into the bags. In that way, the air bags would help prevent the coils from compressing, and I would retain the 1 inch of lift.
Could always look at cargomaxx springs. The set i have (in my signature) gave me 1 1/4 in of lift and ride amazing. No bags or other stuff necessary. And it will squat less when hauling and handling cornering better.
Ill add to the confusion.. Bilstein also has offers a B12 spring… 1.5” inch lift and is a progressive spring which will lift and not take away from the ride quality when loaded or unloaded. IIRC gave me about a 1.5 in the rear unloaded and about a 1” lift or so with my usual jobox and tote/cooler I carry.
Icon has a 1.5” lift coil I believe with an accompanying shock I believe. They’re digressive though so are better for hitting rough terrain hard compared to absorbing highway expansion joints.
I ran an Icon stage 3 set up in my 23 Ram. The rear spring/shock combo rode great. Got the true 1.5 lift unloaded. Didn't seem to drop much when loaded either.
I've got an extra set of ICON rear springs and shocks that I can give up for cheap.
I could possibly be interested in them depending on what cheap is, and shipping cost if you aren't close to Nebraska
Dm me. We can make it work.
I had them for sale but can't get the post to link. Search the title below for pics. Don't pay attention to the price.
ICON Rear Shocks/Springs in NY​
Where did you land on your setup? I've got a rear spacer in the rear of my non-ORP Laramie. I also have airbags in the stock coils. GREAT set-up for heavy towing but I'm not towing as much these days and definitely not nearly as heavy. Unloaded, the rear end rides more like a 3/4 or 1 ton and I'm a little tired of it given I don't need the top end of towing utility any longer.
So, I've been thinking about the same types of setups. ORP or Icon springs, maybe swap stock rear shocks for Bilsteins etc. and I'm ready to pull the trigger but just don't know what direction to go.
So I want to lift my rear end about 2 inches because I'd like to get some slightly bigger tires in the rear to give it that more muscle car look in my opinion. I've been told the best option would be to find a new pair of leaf springs. Any info from personal experience or general knowledge would be great
Rams use coils. So, Get two inch longer coils or pucks. Pucks a fine in the rear. Coils are better.
Whoever told you to get new leafs springs should stop giving you advice. You can get taller coil springs, or use a spacer. Don't forget to change your shocks out for some meant for lifted suspension
