2025 Ram 1500 4X4 Alignment/Steering Issues
Mthamilton7
I have a newer 2025 Ram 1500 4X4 and it pulls to the right. Enhanced at speeds in excess of 55 MPH. Had it in for 4 alignments since purchase. Each time the specs show green and good. Still pulling after each alignment. Steering wheel off slightly to the right and turning wheel left is stiffer than turning to the right. Radial pull eliminated as source. In another forum I connected with a 2025 Ram owner a few days ago with the same issues who said their dealer is waiting for updated alignment specs from RAM as apparently the 2025's are being aligned using 2024 and previous year specs. 2025's have different engine? May be the problem. - any thoughts out there?
Lighter engine with less weight on the front axle? Should not be a cause for pulling tho.
I have a lifetime alignment agreement with Firestone on my truck. At the last alignment the folks at Firestone, stated, that a RAM 1500 should have a cross-pattern rotation for the tires. So I learned something that day. Another member noted the tire pressures they run, I use 39 front and 38 rear cold this is in PSI for those that may use KPA.
I too have had problems with the alignments being "off" despite the measurements in the green. Last time I was just so fed up, I drove 4 blocks and drove back to the shop and complained. The truck tracked amazingly well except, the steering wheel had to be rotated to the passenger side (right). If I centered the wheel vertically/straight up and down, the truck would pull to the driver's side/left a moderate amount. I encouraged the shop staff to take the truck to drive for themselves. They, "made an adjustment(s)," so the wheel is now vertical, but it does not feel as if it is tracking nor, is it as responsive/tight.
Another member quoted a post and it mentions something about resetting the electric steering system at the dealer.
What does that really do? I understand that it somehow recenters some sort of sensor is that correct?
Can non-dealers aka Firestone do this work?
Can I do this reset using AlphaOBD - I have this equipment and do have minimal competency in its use.
So if it can be adjusted/rest using AlphaOBD, could somebody chime in and provide the detailed instructions to accomplish this goal, please?
If this is a dealer-only function, what do I ask for so that the dealer can perform this "reset" of the electric steering system?
Thanks in advance for your help, I have learned so much from the members here.
BlueHemi1500
I’m glad this is not just me. At highway speeds you begin to battle the steering wheel to stay in the lane because it constantly wants to throw you right.
I was thinking about taking it to get aligned but now that I have read this I will ask if those 2025 numbers are out yet. Thank you
I have a '21 Rebel that had perfect alignment from the factory. I put on the 2" level and decided to get an alignment, even though it seemed fine. The dealer aligned my truck 8x and still didn't get it right as the steering wheel was slightly left. If I centered the steering wheel, I was drifting right. So, I aligned my toe myself by centering the wheel and using the old fashioned string method to move the toe of both wheels to the left. My wheel is now straight and my truck tracks straight.
After multiple trips to the dealer after some front end warranty work they were unable to get the steering wheel aligned in my truck. 5 minutes and two wrenches I did it myself and took it in for an alignment at a shop I trust just to make sure it was good.
If your steering wheel isn’t straight when going down the highway simply adjusting both tie rod ends 1/8th to 1/4 of a turn at a time will fix the issue. Mark a line on both inner and outer tie rods to keep track of your progress. Both sides are standard thread (righty tighty, lefty loosy).
A crooked steering wheel really bugs me when I am driving.
