Disconnected battery, check lights not going away...
Slutzk
Cooling off
Arizona
Yes I know when you disconnect battery I can take up to 24 hours, but its been almost 3 days now and traction control, sos, serv 4wd, check engine light and parking sensors still not going away. I disconnected the battery to mount a auxbeam switch pannel and never went back to normal. Ive load tested the battery and checked voltage and it all checks out good. What do yall think? Anyone had there lights stay on this long after disconnecting battery?1000011348.jpg
As I understand it, it's not just the amount of time that has passed, but the number of start/run cycles too. I watched when walmart installled my AGM and they did 5 cycles in a row and all my lights were out immediately.
Curious, did they start and shut off the engine 5 times, or simply push the button put to run, then off 5 times?
Correct me if I am wrong but don`t you have to have the SGW bypass and a scan tool connected in order to access the ABS module to clear the codes?
