2025 Ram Big Horn Misfire code (P0300).
came herew to chime in as one of the unlucky 2025 owners with misfire code on cylinder 3 on my day-old 2025 3.6 bighorn. my lease was up on my flawless 2022 bighorn that had the 5.7, I literally had zero things go wrong with that truck in the 33,000 miles and 3 years i had it..
got my 25 the day before thanksgiving and it idled a bit rough in the heavy rain that night.. TG morning it had cooled down to a frigid cold so I remote started which failed as it set the misfire code.. I copied the info and cleared it down but it came right back on that friday morning. (it was even colder out). took it in a couple days ago and they found theres already a star case open, so they updated with my info.. the TSB indicates on 3.6 2025s that cold weather is a factor in setting the code and to return the vehicle to the customer no curent fix available. sad since my previous 2 rams were such good trucks.. I almost went for a laramie with the 3.0 but a buddy of mine is on his second 3.0 in his grand wagoneer so i opted for the bighorn with some added electronics and creature comforts i wanted... hope they get a fix because i want to use the remote start for whats already started as a cold winter here in ohio..
Update on mine, manufacturer says no more diagnostics needed at this time. Just replacing fuel injector and spark plug on cylinder 1. They had to order parts from Detroit so hopefully early next week I’ll have it back. Took them almost 3 weeks to determine a bad fuel injector? Not convinced but we’ll see.
update: dealership replaced fuel injectors and spark plugs. They test drove it, worked great. Then then let it idle for 20 minutes and lo and behold same miss fire issue in cylinder one.
Next Wednesday will be one month they have had my truck. Probably gonna get a lemon lawyer at this point but am torn cause I love the truck!
That sucks
They have a fix PCM update was released/if not it will be soon. I am talking about the 3.6 only not the 3.0.
Mine just went back in today for its second time and the dealer echoed what’s said here there is a brand new software update. They are going to apply it today or Monday .
thought id come here and give an update... after the software updatre my truck went dead as a doornail sitting on the dealer lot overnight... no power no door unlock etc... dealer got the door open manually and it wouldnt start or light up.. not even a dome light.. then all the sudden the alarm went off and the truck came back to life... ..they checked it out no codes or anything... ive had it back for about 9 days now including a couple 12 degree F mornings and zero check engine lights or rough running... also notice it idles smoother esp when cold.. im thinking they got it all fixed up.. remote start works every time now too. Looking forward to enjoying my new truck like i have the last 2 Rams :)
Hello guys,
I recently bought a 2025 RAM 1500 Big Hirn from Ryan Auto Mall in Buffalo Minnesota. As I am driving it home from dealer the engine light came on. I called dealer and they told me to take it in for diagnostic. They run tests and came to the findings that it have a code P0300. Now, the technician told me he can’t fix it because the engineers at Dodge manufacturing is working on a fix. This code means a misfire of one or multiple cylinders. Also it can lead to increase fuel consumption. This defect was first discovered in August 2024 but Dodge auto maker. I feel as if I was being deceived by the dealership and not told about this defect. Also the customer rep from dodge told me if continue to use drive truck it will stall. And when the engine light is on it will not start with the remote. I live in Minnesota where winter is brutal. I need to remote start my truck before I drive which is good for engine and defrosting during winter. I want to return this truck cause my expectation of buying a new vehicle is that there will be no issues. I am very frustrated about this and have to drive over 100 miles each time going to dealer and back.
I would all start using the Lemon law and purchase something else. They should disclose the issues with the trucks. I have a 2020 ram, lease is up soon and was going to get another ram but , I need to look in to these issues first.
I bought a 25 RHO and am having misfire codes in the first 70 miles. Dealership is saying it is just a software push, but the signs are there that it could be an issue. I haven't had the vehicle over 2500 rpms and less than 55mph so we will see. I'll let people know the issues I encounter. My light has been 4 times, two under acceleration and twice and cruise. The two acceleration you could feel a shutter, the others you couldn't. When I ran codes I had something like 15 different ones, but they were all related to the misfires
Thought I'd update the thread—it helps to get this off my chest.
My truck has been sitting at the dealership for a month and a half, and it's still not fixed.
I filed a lemon law claim three weeks ago, and they told me it could take 30-45 days to hear back from Stellantis.
I also opened a case with Ram Care, but my case manager has been absolutely useless. On top of that, communication is a struggle because I can barely understand him.
The dealership did provide a rental, but it’s a Nissan Rogue :rolleyes: I mean at least give me a loaner truck. I know.....first-world problems, right? but I’m paying for a truck I don’t have, and my patience is running out.
From what I’ve read, this could drag on for months before the lemon law process is resolved.
Anway, hope this gets resolved sooner rather than later.
Sorry for your issues.
Ditto for me with Ram Cares - useless and couldn't understand him and did not call back UNTIL repaired.
No loaner for me while it took 4 months to get my motor replaced under the "lifetime warranty".
On a positive note the motor was replaced and only cost $100 plus tax.
Best wishes resolving the issues.
I will not pay a dime for any repairs I can tell you that 😂 I personally find it amazing the consumer has to be inconvenienced during this, especially if the lemon law states I am well within my right to get my money back or a new truck right now.
Hello guys,
You can skip arbitration and go straight to getting a lemon law attorney. I just went to arbitration for my 2025 Ram 1500 with v6 e torque and 2900 miles. In shop 4 times for same code, TSB applied, and recently cylinder head replaced.20250226_055516.jpg
They haven't performed latest tsb update that has been released?
Yes, they did. It came home for 4 days and back in. Came home again on Feb 22 with a new cylinder head. So far so good but it's only been 4 days.
Check engine light popped up this morning (P0300). ‘25 with the Pentastar. Went to dealer. They logged the code in my account. 2800 miles. If the code comes back, they will take it in and troubleshoot.
Good luck. 400 miles after getting mine back with a new cylinder head that was the 'problem', CEL returned. 3,500 miles old and going back for a 5th time.
The fix still working for you? Just had the P0300 on my '25 3.6 etorque at 1500 miles. Taking in to dealer tomorrow.
Picked up my 2025 Limited Longhorn on 3/28/2025. Had P0300 (random misfires) along with codes for misfires on each cylinder at 587 miles while driving from Austin to Lubbock (made it to Brady, TX) on 3/30. Truck still ran ok at highway speeds so since it was a Sunday I drove it the rest of the way to Lubbock.
The next day (3/31) Frontier Dodge in Lubbock found a vacuum hose between the throttle body and air intake that had come loose; they said it looked like the factory just didn't push it all the way onto the nub. I'm back home in Austin now with nearly 1,500 miles on the truck and it hasn't missed a beat since the vacuum hose was put back on.
i really figured this thread would be a lot bigger 😂. I have a 2025 Ram 1500 Bighorn, picked it up early April. It was even a demo. About 2 weeks into owning it did I get the awful P0300 code. I took it to dealer, they did a PCM update and cleared codes. This past Saturday, I started truck and it was flashing check engine light and idled rough. Shut it off and back on, no issues. Then yesterday, the P0300 and solid check engine light returned. Planned to drop it off today at dealer and I started a Ram case. Imagine the face I had when the check engine light turned off on my way to the dealer. So I turned around and went home. Let truck sit and idle multiple times throughout the day, but check engine light won’t come back on. Now I sit and wait for issue to return. Dealer told me they have 2 other Rams torn apart to trace the issue, so it sounds like Ram still has no plan of resolution.
I spoke too soon in my post from April 7th. Vacuum hose came off again at around 2,500 miles while driving on I-35 between in Austin. Stopped in at my normal local dealer and while my normal service advisor and I were waiting for a mechanic to come take a quick look (we couldn't find any hoses off or loose) one of the other service advisors found the culprit and pushed it back on. He then tugged on it and it came off pretty easily so we theorized that the turbo pressure was causing it to pop off. Mechanic said bad hose and the service advisor got one ordered and said it'd be a week or two.
Didn't even make it home before it popped off again (which was my fault, I got on it HARD to see if it would fail). Used a simple twist tie off of a cable to secure it and it didn't come off again (picture below for reference in case it helps someone else).
Dealership finally got the new hose in and the mechanic found it wasn't a faulty hose after all. Turned out to be a bad connector on the manifold... 48 hours later and my truck had a new intake manifold and it hasn't come off since. I've driven it another 2,000 miles since that point and it seems to be fine now.
