When you turn the setting off in Uconnect, does it go back to normal? Could be a bad sensor.As stated, my drivers side mirror has the auto dim on permanently. Tried to do some researching on my own and coming up empty.
Hoping you guys can help troubleshoot, thank you in advance
Ok so slight update, I tested what you said and I think the problem is actually my passenger side. I noticed that when I turn it off then on the drivers side works and passenger does not.When you turn the setting off in Uconnect, does it go back to normal? Could be a bad sensor.
Yes, sounds like it.Ok so slight update, I tested what you said and I think the problem is actually my passenger side. I noticed that when I turn it off then on the drivers side works and passenger does not.
I assume like you were saying the passenger has a bad sensor
