smashweights
I noted this abnormal wear pattern on my stock Bridgestone Dueler H/L tires, posted about it here and the consensus was alignment issue. Wear pattern seemed to fit with a toe problem. So I had the OEM Duelers replaced at 34k miles with Conti TerrainContact H/T XL tires at that time in March 2022. I had the shop do an alignment then, not much was off, very slight right toe off, and the front right/passenger tire seemed to wear this spot fastest. Had them redo the alignment a year later at 44k miles (had a 1 year alignment plan) and toe went slightly off the opposite end of spec. I'm now sitting at almost 60k miles and the outer edge/toe wear seems to be developed on the new tires as well. I had to take the truck in to the dealership anyway for the ABS/ESC recall and asked them about the wear. They "didn't notice any abnormal wear" but rec'd doing an alignment again. Seems the caster was way out of spec and comparing the previous non-dealership alignments the specs they used were slightly off and a little high even post-alignment.
Interestingly, the initial alignment lists the truck as "DT... Lifted Rebel/Off-road" which it's not a lifted rebel/ORG and the second lists it as "DT... steel suspension" instead of air ride. The dealership here put it as a DS, so has no one ever used the correct truck for an alignment???
So here I am still noticing this outer edge wear with new tires and 2 alignments after about 26k miles. The horrible wear is the OEM tires for comparison but if you look at the treads on the new tires, you'll see the siping is nearly or completely toast on the outer edge in a similar area to the OEM tires. I have had the tires rotated and re-balanced with every oil change and am religious about keeping my tire pressures around 36-38psi cold. These are 70k warranty tires and i'm not even halfway through that rating and i'm concerned the outer edge is going to significantly impair the lifespan yet again. Any other suggestions?
