Steering Noise
I have a 2019 Laramie Longhorn with 80k miles. I'm getting a random "rubbing" noise coming from the driver's front. Can't tell if it's under the hood or not. Seems to happen when I'm only turning right and am on a slight decline. Only happens at low speeds. Any thoughts?
Did you ever find out what the noise is from? I have a 2019 Bighorn with about the same mileage and similar noise problem.
Thanks, it goes into the shop next week and I'll see if they check that.
Eps power steering holding bolts to frame loose or if grinding noise it comes from belt inside eps
What exactly does it sound like?
Sounds like grinding kinda sorta, but usually only slow right turns for me. The dealership was supposed to do the software update while in for manifold, but not sure if they did and I live 2 hours away.
